The PCM uses input from the speed sensors, engine rpm, throttle position and temperature sensors all to control overdrive. Get a scanner on it, check for codes, check your sensor data and go from there. I feel like a broken record on this site lately.
Hard to get it scanned when it seems no one has an OBD 1.5Gotta scan it to see what's up. Most likely it's a temp sensor issue as overdrive is inhibited until the engine and trans warm up.
OBD1.5 was only in late 94 and 95 in S10's, Camaro's, and 1 or 2 others. A 97 by federal law is obd2.Hard to get it scanned when it seems no one has an OBD 1.5
