3D printed Suspension part!! ??
dbrannon79
I'm getting there!
Seguin, TX
Hey guys, I just watched a video where they 3D printed bushing and motor mounts out of TPU and they held up perfectly fine. TPU is thermal poly urethane, a form of rubber that is widely used on a lot of things. I was amazed at how things held up and wondered if others have heard of this. gives me thought about making a set of sway bar bushings for my son's 68 chevy and see how they hold up.
I don't think I would try it on any critical components that if they fail, it could cause damage or an accident, but it is an interesting thought.
Even found a couple of files where folks are sharing their designs of functional bushings.
Most 3d printed parts have the weakest point between layers. printing in the right orientation is key to strength depending on what it is. most of the parts I have done in the past with TPU I really haven't see separate between layers "yet"
I would think if we increase nozzle temps some along with little to no cooling from the part cooling fan you would get the optimal layer adhesion. But there is a point at which overhangs and bridging will be effected and supports are needed. My H2D can run two materials at once for easy supports.
I may try to print something like a round bushing with a large top and bottom lip and try to rip it apart and crush in my vice just to see what happens.
informative video and and forum thread on this very subject
