dbrannon79
I'm getting there!
Hey guys, I just watched a video where they 3D printed bushing and motor mounts out of TPU and they held up perfectly fine. TPU is thermal poly urethane, a form of rubber that is widely used on a lot of things. I was amazed at how things held up and wondered if others have heard of this. gives me thought about making a set of sway bar bushings for my son's 68 chevy and see how they hold up.
I don't think I would try it on any critical components that if they fail, it could cause damage or an accident, but it is an interesting thought.
www.facebook.com
Even found a couple of files where folks are sharing their designs of functional bushings.
makerworld.com
makerworld.com
3D Printed Car Parts | Rear lower control arm bushings for 88-91 Honda crx the bushings file I took from a del sol 95a tpu 100% infill | Facebook
Parametric TPU Custom Suspension Bushings - Free 3D Print Model - MakerWorld
Download this free 3D print file designed by CUBEIFY. Parametric Bushing ToolThis is a parametric tool designed to create custom suspension components.It can create standard round bushings, flat sided sway bar bushings with side cut outs and engine mount style bushings. It also allows you to...
TPU Bushings for car suspension - Free 3D Print Model - MakerWorld
Download this free 3D print file designed by Meggotina. This approach is still under testing This is a custom 3D-printed bushing designed for the Toyota Hilux. It has an outer diameter of 40mm and an inner diameter of 14mm. The bushing was printed using 100% TPU A95, a flexible yet durable...
