2010 tahoe
Trucker2k16
Charleston south Carolina
Hey guys i just bought a 2010 tahoe for 2 grand i have a code for oil pressure sender and at times it says shit engine down but have verified i still have good oil pressure. I noticed the stabilitrak service and traction control are both off and the only other codes i have are right rear wheel speed sensor and all 4 tpms in tires my question is will tpms cause this issue? I understand its a common issue when wps fails brake20210904_174717.jpg20210904_174732.jpg20210904_174746.jpg20210904_174809.jpg20210904_174816.jpg20210904_174821.jpg20210904_174709_HDR.jpg light switch etc
Will L.
Boulder City Nv
First, you got ripped off, but since I like you so much I will get you all your money back plus a hundred bucks and take it off your hands! Haha!
Dude that is nice.
I would gamble the oil pressure sensor and just throw one at it if the connector looks good.
Try brake cleaner and rag to remove any metal shavings of wheel/brake sensor and make sure tone ring isn’t cracked. After that throw a sensor at it. There it is, the two barrel parts shotgun technique- no more loading parts into the shot gun. Only because those two are common failures and cheap while being easy to do.
After that clear codes and try again.
I am unfamiliar with how the tpms would mess with any of it. Afaik a tpms can read 0psi and truck still drives the same, but I am old and out of touch with what they might have tried in the name of safety.
Now that I am done, hopefully the smart people can begin answering.
Congrats on the find!
Trucker2k16
Dude that is nice.
Yea my first newer ride lol only has right at 200'000 miles on it it drives great runs great and only sold it cause the rear main seal and check engine light which is only 2 codes.
Trucker2k16
Dude that is nice.
I was thinking the same brake dust dirt etc on rings and sensor has all specs 0.5 reference etc hell for all ik the filter could be dirty under it.
WarWagon
Well it hits on 7 of 8...
AZ
Clean the connector for the wheel sensor as well. Had a bad connector that drove us nuts and extended warranty replaced the ABS computer and the sensor many times. GM has had terrible luck with their low bidder receiver for the TPMS and remote entry. If both are INOP it's the receiver antenna thingy... I don't know what year that combined antenna device started.
WarWagon
AZ
Oh, and congrats on your new job... Of keeping Black paint looking good. 🤪 It either looks outstanding or dirty with zero in between.
