handcannon
I'm not sure if this is the best place for this as this is dealing with ABS brakes, but since it is not a diesel I guess this will do. If it is OK to be in the brake section then maybe a mod could move it there.
My wife's car, a 2005 Buick Century, has four wheel ABS. It has been intermittently setting the SES and anti-lock brake lights, and recently started setting the emergency brake and low pressure (fluid level is good) brake light. When they come on all I have to do is shut off the car and re-start it and the lights will be off for a while. The intervals between when the lights come on has been getting shorter. My wife has complained also about a "vibration" she occasionally feels. I also felt it just recently, and I'm thinking the ABS pump running is the "vibration".
Today I took the studded tires off, and while doing that I checked the wheel bearings and brake pads. The wheel bearings all turned smooth and had no loose feeling to them. The rear pads are still in good condition, but the front needs to be replaced.
We don't have the funds to take the car to someone else, so I'm the primary mechanic. I have no experience with ABS brakes so I'm just guessing. But, I'm thinking that since the lights are easily shut off just by re-starting the car that the problem centers around one, or more, wheel sensors. I have not tried reading the codes as I don't have a code reader. Sometime this week I'm going to try to meet her in town to see if I can find someone to read codes.
Non-ABS brake work is not difficult for me as I have done all my own brake work for a number of years. I'm just hoping someone on this forum has the experience to walk me through diagnosing and finding the problem with the ABS system.
Don
Don
