Max Attitude
Typical White Person
This work truck has been sitting for maybe 5 days went to start it up and the battery acted dead. Jump started it and drove around to charge it up but the rpms would dive if I let off the throttle. It stalled twice before I got it back to the shop. The first time it stalled it wouldn't start again as if the battery was dead. 10 seconds later it started right up. The voltage gauge shows around 14 volts so I don't think it's the alternator. The battery cables are tight and all the wires are on the spark plugs. The mas airflow sensor was replaced not too long ago....I checked the plug and it was all intact. I believe it's some sort of wiring issue. Any ideas? I'll bring my Predator scanner tomorrow to check for codes.
