Yes the three rubber lines under the hood two on the filter housing are easy the third goes across the top of the front of the intake manifold it takes a little work to change this one. Don't buy the ones from Chevy they are way over priced all you need is 1/2" diesel fuel line to replace them with at a fraction of the cost. We are a Diesel shop and do not normally attach ourselves to sites like this but I saw the information from thefermanator.343 I thought he was a good guy trying to help others. Then you get a smart ass comment from another member(Mad Maxx) and you remember why you do not link yourself or waste your time with these sites. The vacuum test for air in the system passed the fuel pressure test passed the fuel pressure regulator act. vs desired tested passed. The injector balance readings were good so if you do all these tests and you still have a lope change these lines and it will fix your problem. Mad Maxx get a life you don't have to use sites like this to make yourself feel more important than you really are, you and others like you are the reason most good mechanics who do this for a living don't participate in sites like this. You need to use thefermanator as a mentor he uses this site to help others not belittle others. Using the internet to help others not as a cowards soap box browns out.
