2000 3.9 Dodge V6 Dakota pickup. So it has over 1/4 million miles towing scrap metal to yard for the Boy Scouts. Around 237,000 miles.
Yeah, wrong tool for the job.
Anyway the #5 cylinder is missing. Computer code with light says so, cold exhaust manifold on #5 vs. the others, you can hear the RPM change with altonator noise change, Tach twitches, and you feel it shake.
Spark good, voltage to fuel injector, injector clicks. Didn't check injector ground path. New injectors installed due to miles, but, had issue randomly before this. Computer takes it's time to turn on light after code reset when condition exists.
Can hear slight tick noise from the engine now and then. Also have heard a hollow thump like main bearings are loose from it in the past.
