ak diesel driver
6.5 driver
might as well do buttons while your in there
Yeah man, good point.Since nobody else is talking about the elephant in the room... Get the PMD out of the engine compartment it will still overheat in there.. get it down behind your front bumper.. I smoked two of them before I moved mine..
Well. Haven't been a problem here yet. But it is on to do list. Not pulling heavy. And, it's Norway. Haven't been over 50 degrees Fahrenheit yet.Yeah man, good point.
 But corrosion.
 But corrosion.
New cover? Wtf. Or gasket?And that uncovered air filter is sucking in hot air from the engine bay, which ruins performance.
If you’re pulling the valve cover, buy new valve cover and do not mess with trying to make the old ones work. The amount of time involved is not worth a redo to adress a leaky valve cover.
That sounds like a normal 6.5.
The covers are made of some mighty thin metal. They bend and easily distort.New cover? Wtf. Or gasket?
And to Me, that is the route I would take. New covers, girdle/stud kit and gaskets.I've gone the bending route a couple times now and they always have some level of leak and it ain't because I'm a dumb monkey with a hammer. Leroy's girdle looks interesting, but I would have to hear from some with direct experience using it. I would still use brand new valve covers with the girdle and probably the gaskets too. In my experience, simply gluing them on with The Right Stuff has dubious success. The damn heads need attaching bolts on each side of the lower corners to get the required pressure to seal it up.
Several times I have used the right stuff in areas of high leak probabilities and sure enough, even though the engine had not been started for several days, that crap washed out and leaked as bad as before. That mainly was on a 1988 Puick Century with a 2.8 V6, intake gasket, and, that is a real PIA to get removed, even after about three times within a year. I come to have a hate/love relationship with that car.
Well after initially declaring victory on my leak with a new valve cover, I am occasionally seeing a dime-sized spot. Not like the palm-sized puddle at every stop with smoke coming off the manifold, but still an occasional spot. Very frustrating as I spent over 8 hours doing the work, removing inner fender, turbo, intakes, and injector lines. Then scraping all gasket material off the heads and vacuuming the particles out. Replacing the two valve retainer buttons that were older. Putting it all back together and torquing everything properly. My hands were knicked up and aching.
Possible fuel leak in the valley
