chestervan
- Messages
- 12
- Reaction score
- 27
Hi there,
I have an early 1999 (8th gen, '92-'99) GMC Suburban ½ ton that has had a pull to the right for years. I've had several shops try to fix it, including the dealership, to no avail. What I know is that the right rear brake is working too hard. It seems to engage when the pedal is first depressed, the front swings right, and then somewhat evens out as the pedal is depressed harder. The right brake actually locks up if the road is wet, and the ABS kicks in. It also gets hotter (quite hot with just a short drive) and wears the tire quickly. I've changed right shoes, drum, wheel cylinder. A shop recently replaced my master cylinder, and said it was fixed but after picking it up I left on an errand that was about 200 miles with the right rear grabbing and smelling hot. I've ground the grooves out of the right backing plate. Because I know the right rear is grabbing I've not paid much attention to the front but I just did a test on my driveway (concrete) braking hard until the ABS kicked in and was surprised to see not only skid marks from the right rear but also some marks from the front right.
I've read on the forum here about replacing proportioning valves. But I don't believe mine has one. From what I can tell there is one brake line going from the ABS module to the rear, where it splits on the rear axle. There are two lines coming from the ABS unit to the two front calipers. Am I missing something?
There is no sign of damage to the lines from the split on the rear axle to the master cylinders.
My main questions are: 1) Is there a proportioning valve I'm not finding? 2) In the absence of a proportioning valve, could the ABS unit be sending too much pressure to the rear or to one front caliper? 3) Are solid brake lines not showing any sign of compression or damage likely to get "clogged" up (yet still bleed as expected)?
My next steps are going to be (unless I'm guided otherwise):
1) Check front calipers. I've replaced them both not too long ago but I'll ensure neither are sticking.
2) Replace front brake hoses.
3) Replace left rear wheel cylinder and shoes and grind out grooves in that backing plate.
4) Try to find a shop that can test the brake fluid pressure side to side and front to rear.
I don't know what else to do and I don't seem to find a shop that can help me.
Thanks in advance.
Thanks in advance.
