Greetings, 1998 GMC 3500 DRW 6.5 diesel no start no codes / 3 IP's one factory new / 4 PMD's using remote and OEM wiring / New lift pump / new filter / good fuel flow through to injectors / cranking with charger assist / new batteries and cables / with new CPS plugged or unplugged / OPS new / tried new throtle also / moved the ip's to many different timing positions always get lots of black smoke no start no codes with all the IP showing a 2.02 injection timing and 13 degrees no matter where the pump is placed / new timing chain /new heath maxtorq ecm / just straight piped it /New vac pump and when it last ran good turbo whistle / it all started with terrible stumble loss of power no start hot / cool off led to rough start with lots of black smoke culminating in no start / glows working fine / all parts since make no change - no start / heavy black smoke till the starter loads up slowing down / 207k on truck. good oil preasure / all work all hired done starting with a simple alignment job with all this happening to our family mechanic...now at a local GMC dealer with a d-max mechanic using T2 with no change to timing learn / 275 PSI compression on a cold dry engine / This mechanic now going to recheck the timing chain...at wits end hope to get some ideas to pass on to the mechanic, if you know a good mechanic on the MS gulf coast please let me know TIA /
