ak diesel driver
6.5 driver
Nice that you could help your dad out.
Yup!I like your dad sitting on the chair, where he should be.![]()
The windshield is cracked and the bumper is rusted through in the middle. Don’t worry, I took every single good part off of it.If I was near you, I'd want to swing by to get that rear bumper and windshield not to mention talk you out of that really nice black camper in the background LOL
Yep, they’re Mevotech TTX that I bought off of Rock Auto. To be honest, the unique castle nut and pin arrangement threw me for a loop and the conclusion I came to is that’s how it was supposed to be and the pin was just there in case the nut happened to come loose - that it wouldn't come all the way off. Now I see the thought process you went through and it makes a lot of sense that the pin is supposed to land in that groove in the nut. I guess it’s washer time. Thanks for catching that!Looking great as always Nate!
Are those NAPA/ Mevotech TTX tie rods? I bought some brand new and the alignment for the cotter pin and castle nut was way off. Wondering if you have the same issue
Napa TTX castle nuts appear too short
Doing inner and outer tie rods on my 1 ton dump project today. Genuine TTX inner and outer tie rods from NAPA. Attaching to the center link, it seems that the hole in the threaded part of the tie rod and the castle nut don't line up at all. Torque spec is 46 ft/ lbs. After tightening down, the...www.thetruckstop.us
You can see the issue in the thread that DieselAmateur linked. I have pasted pictures from his thread below. The hole in the stud is about .200" from engaging the castle nut. The nut isn't short, it just isn't lined up at all. I'm going to shim it with some washers and call it a day.I am not familiar with that brand's part, do they use those new-style "shorty" castle nuts that have a really shallow body on them like 4-5 threads deep? One picture worth a thousand description words (and less questions asked).
I had another brand's tie rod ends ends that I installed on my Camry a few years back that had the same issue of the new castle nut was too short to have the slots reach the hole in the shank.
I just went over to the neighborhood Tru-Value hardware store and got a couple of metric Grade 8.8 castle nuts from their Pik-a-Pac section. Found that those had the old-school taller body with 10-12 threads in them. When I used the hardware store castle nuts, the slots were aligned with the factory hole in the shank depth-wise just fine to use a cotter pin.
