1995 k2500 2 door extended cab 4x4.
jamesD
I had to have this truck shipped from North Carolina and paid 1,750.00 for it. I installed a Unique marine grade 6.5 diesel, a roller bearing turbo with a wicked wheel 2, a custom tri-flow radiator with dual Spal fans, a custom cold-air intake, a high-flow upper intake, a Fass lift pump, an HP injector pump, HP injectors, a reprogrammed vacuum pump delete high torque chip, 4-inch exhaust, relocated engine oil cooler with a Spal fan, 2-inch lift with modified suspension, rebuilt and modified automatic transmission, completely redone interior, ALL led lighting, carbon flash metalic paint and bodywork from TLC Auto Body, a fantastic sound system from Special Effects in Lowell Michigan and a 91-gallon fuel tank in the bed. The total cost of this project was about 40k. I have a very understanding wife who married a gearhead. This truck is better than a new truck, gets better mileage than a new truck, and was MUCH cheaper.
