Typically if the computer doesn't have a code in it leave it alone. Make sure you understand what it is and how to adjust it before you even try. Otherwise you can limp the transmission. Limp means 2nd gear only! Then you have to adjust it properly to be able to shift normally again.
There is no Service Engine Soon light for a maladjusted TPS just a stored code as shifting is NOT an "Emissions" problem. So you will have to paperclip and read the codes or read the codes out of the computer to be sure.
Idle speed adjustments tend to throw the TPS adjustment off.
A Scanner can read TPS% and look for flat spots. So can back probing the sensor wires and opening and closing the throttle with the engine off.
Lets get a picture of the Injection Pump and see of it is a mechanical or electronic pump. Just because the year means electronic for civilian stuff doesn't mean military used it. :rolleyes5:
Normally a DB2, mechanical IP, has the TPS sensor on it and a throttle cable going to the pump.
We adjust the sensor on a 1993 without the gauge block by voltage. You have 5v source, output voltage, and ground. You want 0.5v at the output voltage, engine off, cold start solenoid that moves the throttle open disconnected: Throttle closed. Your 1995 HUMMER may be different - I don't know for sure.
