On the glowplugs use only Bosch duratems or AC Delco 60g.
Do not use starting fluid! Way high chance for engine damage, ruins glowplugs first time, etc.
Quick test for hard starting when hot is when it is doing the problem hop out and pour cold water on the ip. If that fixes the problem then it is usually a worn out ip. Don't just grab a rebuilt one, lots of scammers out there that don't rebuild them 100%. The guys here will speak up if that's the problem on who to trust.
For air in the system, replace the 1/4" x about 4" long ip return line that comes out the front of the ip with clear line. You can see the bubbles. There will always be a tiny bubble in there- that's ok, your looking for a stream of bubbles. Bleed air at the injectors just like the cummins.
Get a fuel pressure gauge with vacuum reading on it. Tap in between fuel filter and ip. Make it a permanent home. Catching a bad lift pump early will save the ip. The lift pump is flow on fail, so the engine will run, but it overloads the ip to pull from the tank.
Read all the stickys in 6.2 & 6.5 section before doing anything else. Well worth it. Going bac in time on this forum will take some time but will save lots of time and $.
