swinters
I've been trying to figure out whether I need to change out all 7 of the same style relays in my fuse box but can't find any info on why GM has changed the part number - twice. Even the dealer hasn't been able to help. Does anyone here know anything about these relays? I don't want to blindly throw parts at the truck. Here's a cut and paste of the post I made this morning on the Duramax Diesel site (no replies):
Several years ago a Chevy dealer identified the Fuel Pump Relay in the underhood fuse/relay box as the cause of repeated P0090 codes on my '07 LBZ. After they finished with it the truck ran for a long time without setting that code again (I did get some other codes but it turned out to be the clips on the back of an engine harness plug). About a year ago it set the P0090 code again so I swapped the fuel pump relay and one of the others (my truck has 7 relays with the same part number), cleared the code and it has been fine until two days ago. Same thing with the P0090 and limp mode, swapped in a different relay (DRL this time), cleared the code and am back in business. Looking at the schematic it appears that this relay, even though there's no factory fuel pump, provides power to the ECM and fuel pressure monitoring. When the relay is open and the engine is running the truck sets a P0090 and goes into limp mode. The first symptom is injector knock when the truck starts and then I get the P0090.
It seems to happen on hot days and day before yesterday it was over 90F, so I decided to see whether they sold a heavy duty version of the relay. The first thing I did was go to a GM parts site and enter my VIN, and then the part number for the 7 relays the factory put in my truck (15328866). The site returned that this part did not fit my truck. I looked at the details and it said that this part was replaced by 19115080, so I ran that against my VIN and it said that part didn't fit my truck either, but then looking at the details it said that relay was replaced by 19116057 so I ran that and it said that relay DOES fit my truck and identifies it for several application, including the fuel pump relay.
I've been trying to find the specs for the different relays and the only thing I've found is that the 19116057 relay carries the AC Delco part number D1786C. No breakdown that shows anything like contact material or coatings, amperage ratings, etc. What I'm wondering is whether the original relays, Part No. 15328866, are defective or inadequate for the load they're carrying and whether I need to change out all 7.
Does anyone have any insight on this issue or know where I could find the info?
