Nick 6.5
Many a person has chased injector problems on LLY'S using there EFILIVE V2 only to learn about only the TECH 2 displaying the correct data streams. GM even went so far as to scramble a couple of the data streams on the LLY so that they change at a certain RPM point. They found the injector disable command would shutoff 1 injector at idle, but as soon as you touched the throttle it would switch to another. Welcome to LLY life and why so many DESPISE them. If you think this is bad, try flashing them. It's like russian roulette everytime you click start flash if it will go through or brick on you.Thank you ferm. I️ figured that unplugging the injectors wouldn’t work. Did an oil change and I have no sparkles in the oil or on the filter element inside the filter so figured is not rod knock. The knock I could hear at all rpm including at idle. I️ did not know about the tech 2 scanner thank you for that.
Which injectors is out of range.Pin point what problem?
