daustin
Hi there guys,
I recently got a GEP engine, i tore it down to have a look before installing it in my '93 Dually. The bearings look mint, cylinder walls still have the crosshatch and heads look nearly new. The piston tops looked new when i wiped them down with a little wd40 and a paper towel, it couldn't have been ran much at all. I used the home-brew method of checking for cracks diesel fuel, lol. Thing was clean clean inside. Only thing i found was the rear oil pan gasket was pushed in and might have leaked. Aside from new head bolts and gaskets, what else should i look at or consider replacing? Rear main seal? Also are the torque specs for the mains & heads the same as the '97 models? The outer main bolts in my FSM say something like 110lbs, same as the inner bolts and the outers are much smaller. THanks for the input, much appreciated.
Don
Don
