Detroit Dan
Started getting a lot of howling noise from the front of the wifes 04 Avalanche 1500. Sounds identical to the front diff on my 02 Denali when it failed. Checked and there was hardly anything in the diff, filled it up with full syn 75/140, didn't quiet it down. BTW, there was no indication of any leakage anywhere. Denali I was told went at 87k because the Denalis and Escalades are AWD, but this is selectable 4wd. Course, it all turns all the time anyway. The Denali cost a fortune to have a rebuilt diff put in, I'm not going that route again. I'll either rebuild it if I can or use one out of a parts truck.
Any idea where I can find info on what years are interchangeable? I'm pretty sure it's a 3:73, of course I will confirm that before touching it. Just need to know if a 2000 or a 2002 or what have you will fit in the 04.
Going to double check the wheelbearings again, but I don't think it's that. Usually a wheelbearing changes sound when you're turning the wheel.
79k and the front diff had no oil in it, the PS pump was almost empty, and I have a tranny line seeping now too. I usually check things every oil change, might have skipped it last time because of the cold, but can't understand how the truck is all of a sudden just falling apart. Just put new shocks in and was about to spring for 4 tires, but going to have to figure out the front diff thing first. Speaking of tires, I wonder if a bad tire could be responsible for the noise? They are pretty worn. But, the diff was so low, that's gotta be the problem.
