That hard 90° fitting is not a good idea. That causes turbulence in the fuel flow and can create aeration. I remember warnings about that from GM.
But yes that is exactly where the T fitting from MM would go. I’m pretty sure MM is just buying and reselling the T. That 135° fitting Leroy sells- I can’t remember ever seeing one like that around normal supply shops. There are plenty of local mfrs that do small run custom fittings. That might be the case here.
As to the sending unit physically fitting there- I have seen a few hummers that stuff d it in there and the hummer intake gets in the way worse. Although a hose from the fitting to the sending unit would work- again it is defeating the concept of no hose deterioration possible of having a difference at the ip inlet and at the sending unit.
I don’t have any pics to share- I don’t own a ds4, I usually gave them away when I ended up with one.
Ok good. Yeah- see how the factory did a sweep and not a HARD 90°
There is a serious reason for that....
Its a good idea, and anyone that can tig themselves could do it easy and cheap. But to pay a pro, they would charge more to weld it up and test it than to just buy the one for $30. They include shipping with their prices.If you still want the gauge find a steel fitting that will fit the T and then find someone to tig it on there after you cut off the hose barb
What the point is- you could have hose plugging and don’t know it. You could have intermittent Lp cutting out. You could have a leaf in the tank that occasionally plugs the sock and you don’t know it.
The expense of $125-150 for metal T, and a gauge is not spending the money and time on a guess of buy a new ip because you know it didn’t have this problem with the ip Marty loaned you for testing.
If he had that fitting reading the pressure at 8 or 10 psi and it died- next thing is open hood, turn on switch and watch clear tube. If it is flowing clear and clean while keeping pressure up- Then ip time.
Or skip the gauge and buy an ip to replace the ip you just bought.
There is the option of hooking up a laptop and having it record everything non stop while he drives and when it happens again note the time. Then hopefully you see something odd happening that one of the ds4 geniuses here could see something. It is a possibility, I am from Vegas so I wouldn’t take those odds, but maybe it could be something noticeable there.
Absolutely could try replacement under warranty. It sure isn’t as good as Marty’s used one was.
I got a pod mount similar except for room for three gauges in one pod. I now have only the RH rear cylinder head temp gauge in the center hole. When I set it up, I run out two extra wires for two more sensors, maybe two FP gaugesOrdered 2 of the fuel pressure gauges:
Amazon.com: GlowShift White 7 Color 30 PSI Fuel Pressure Gauge Kit - Includes Electronic Sensor - White Dial - Clear Lens - for Diesel Trucks - 2-1/16" 52mm : Automotive
Two of the single gauge pod mounts:
Amazon.com: GlowShift Universal Black Single Gauge Console Dashboard Pod - Fits Any Make/Model - ABS Plastic - Mounts (1) 2-1/16" (52mm) Gauge to Vehicle's Dash : Automotive
And two of the fuel pressure gauge adaptors:
Fuel Pressure Gauge Adapter | Mod Mafia
I've asked MrMarty to send his loaner IP directly to my son. We will test again but really need the box it came in as we can return via Amazon up until January 31st.
Colby will have some work to do the next couple weekends. Though by now he's well down the learning curve on IP removal and install.
I got a pod mount similar except for room for three gauges in one pod. I now have only the RH rear cylinder head temp gauge in the center hole. When I set it up, I run out two extra wires for two more sensors, maybe two FP gauges, Within the pod, I also pig tailed out two keyed/batt + pigtails and also two extra ground pig tails. Just to be a little ahead when I do decide what I in the two extra pod mount holes for gauges.
Mine is like this one. I trimmed aand fit a piece of aluminum for the open bottom.
