JonnyTheKidd
- Messages
- 14
- Reaction score
- 35
so i replaced my injection pump. I'm new to diesels. i got the timing close 2.9-3.5. but it is running like crap i bled everything the filter, return lines, injector lines cracked them 1 by 1. the truck was running fine with the old injection pump it was just leaking fuel and filling the valley. i took the new one off putt the old one back on with the marks i made lined up and ran the same as it did with the new one. in park it idles high around 1500rpm and wont come down even after it warms up. if i put it in drive it will even out and not sound so choppy but still sits around 1000rpm. it also gives itself short revs. here's a link to a video of it running, help would be awesome cause I'm lost as to why its running like this.
link to truck running
like to the Actual IP timing not sure if i should advance it more or retard it more
thanks in advance for any and all help!!
