corolla
Recruit
Can get a reader that displays some "Live" data such as EGT, MAP, and reads codes, but not volts or coolant temp,is it a wroth while purchase for $133.00?
My mistake the "Live" data on the 96 was IAT, MAP otherwise not much else. The 99 Toyota had more information available including EGT, go figure.
Does the Autoenginuity SW provide more "monitors"?
Where does one obtain a cable and interface for the 6.5, any concerns on which type of cable and interface to get (VPW)?
Engh Motors is OBDI only.
Corolla, Google "Alex C. Peper" and "Car Code". While it is not as elegant as some of the others, it does real time monitoring and provides a lot of functionality for the money, about $122. It also does TDC Learn and other useful functions for our trucks. Fair warning though, it takes some practice to use effectively.
It will read TDCOffset but I'm pretty sure you have to do the key-on key-off to do a relearn. Leo
No, you can actually command it to perform a relearn. It is tricky and not as straight forward as a TechII, but none the less, it is possible. It also has the capability to shutdown individual injectors and other noted diagnostics for the 6.5. I have not tested this functionality, so this is pure speculation on my part. I'll try and get some screenshots posted later on.
On edit, I have performed a relearn on my truck using this tool. The statement that I made about not testing the functionality is in regards to speedometer calibration. My brain got ahead of my fingers.
