sorry for long post in advance,
lube gaurd has been out for quite a while. it is a friction modifier and fluid conditioner(helps reduce friction, extend life of fluid and tranny) look up on web.
dexron VI was developed by GM of Canada in conjunction with Petro-Canada and Afton Chemical Corporation. The main difference between Dexron-VI and prior Dexron releases is the added low-temperature performance and shear stability due to its build and lowered viscosity. (6.0cst) It is considered to be lifetime fill and is expected to last 100-150K under all service conditions
DEXRON®-VI ATF
General Motors Powertrain has recently upgraded to DEXRON®-VI ATF with the start of 2006 vehicle production.
Only 2005 and prior models that currently use DEXRON®-III may use DEXRON®-VI as a replacement.
All 2006 and future models that use DEXRON®-VI are to be serviced with DEXRON®-VI fluid only.
DEXRON®-VI is an improvement over DEXRON®-III in the following area:
DEXRON®-VI
Extended Factory Fill For Life 160,000 km (100,000 mi) For Cars and Light Duty Trucks*
80,000 km (50,000 mi) (Severe Use) For Cars and Light Duty Trucks*
Clutch Friction Stability Improved 100%
Clutch Durability Due To Fluid Improved 120%
Oil Film Thickness Increased 20%
Fluid Oxidation Improved 100%
Foam / Aeration Improved 150%
Shear Stability Improved 200%
* These ATF change intervals remain the same as DEXRON®-III for the time being.
2006 Transmission Fill and Cooler Flushing
Some new applications of the 6L80 six speed transmission will require the use of the J 45096 -- Flushing and Flow Tester to accomplish transmission fluid fill. It is highly recommended that the clean oil reservoir of the machine be purged of DEXRON®-III and filled with DEXRON®-VI.
General Motors has introduced a new ATF specification it has termed Dexron® VI. GM decided it needed to upgrade its ATF specification to accommodate the Hydra-Matic 6L80,
its first 6-speed automatic. This fluid is the new service fill and factory fill specification for all Hydra-Matic GM transmissions. It will be used as a factory fill for all 2006 MY Hydra-Matic automatic transmissions starting on April 4, 2005, and it will be mandatory service fill by January 2007. Dexron® III(H) or Dexron® VI can be used for service fill until January 2007. Dexron® III(H) approvals will be valid until December 31, 2006. Dexron® VI is backward compatible with previous Dexron® formulations. Dexron® VI will be offered through GM Vehicle Care products in dealerships and service centers in Summer 2005.
GM believes this new ATF is two to three times better than the best Dexron® III(H) fluid on the market, today. Some of the enhancements of the Dexron® VI include significantly improved shift performance and fluid durability as well as superior pitting protection, oxidation stability, foaming protection, and shear stability.
also look at Redline D6 ATF Full Synthetic fluid, Mobil DEXRON-VI ATF, Allison Castrol TranSynd , Valvoline has a full synthetic Dexron VI, Royal purple GM - DEXRON VI no RP equivalent,
