Engine RPMs revving while driving
I just pulled the fitting from the top of my IP, but it definitely does not fit the threads on the Mod Mafia part. The IP fitting can fit entirely inside the MM part without threads even touching. I have not yet tried to see if the MM part threads into the IP.
My understanding was that the MM part just went right inline without any additional parts. Is that how its supposed to be or am I supposed to have some other reducer to mate these two parts? Wondering if they sent me their part for the mechanical IP by mistake.
Furthermore, trying to thread the Mod Mafia part into the top of my IP has it so up against this cylinder that there's no way to even rotate it in. I'm getting the "I have the wrong part" vibes. Which I may be misinterpreting as "I don't know where this is actually supposed to go." Looking for confirmation of either of those...
Thanks.
Mod Mafia claims they sent me the correct part for my truck, but they're checking with their techs to see what issues they've had with the 6.5. This is definitely not the right part for my truck.
Does anyone have photos of this Mod Mafia fitting installed on a Hummer?
@mhixson the fitting treads on this part is called a #4 male boss o-ring fitting. go to your local Napa or hydraulic shop and ask for a male #4 boss to male -6 an fitting to attach the MM fitting to the IP. this will leave you with the male end if the MM fitting sticking up. this is where you will need a 90 degree female -6 an to 5/16" hose barb to connect to the fuel hose coming from the FFM. This is where most install the "feed the beast mod" which is a modified FFM that uses 3/8" hoses instead of the 5/16".
BTW -6 an is the same thing as #6 JIC. it's a 3/8" 37 degree flare fitting used in hydraulics. it all depends on what folks want to call it. :)
this is the male #4 o-ring boss
What was the conclusion on this? I was about to order the Mod Mafia fitting but if it isn't going to fit, then I'll put the $65 elsewhere.
@Will L. did you happen to discuss with him further offline in case he doesn't frequent the forum anymore?
I haven’t had him call me in a couple years.
(844)416-2342 is his shop number. Give a call Monday & ask.
Remember stock is 5/16” and FTB is 3/8”.
