My pinion seal is starting to sling some diff lube, not a lot but is making a mess. My question is this.....would it be a good idea to go ahead and replace the u-joints and the center support bearing while I'm at it? I got the truck in 2010 and it now has 140K. Not sure but I think they are all original parts. Other than the leak everything seems to be fine (no vibrations or noise). Being a '95 and 30 years old now.....would yall recommend replacing these parts "while you're in there" or just fix the pinion seal?
