Big T
The prices justify my fixing up and painting the ‘94 and ‘99 diesel K2500s.No gasser unless it's dirt cheap
You did save Your 6.5 diesel pulley ?Installed a new CS-144 250 amp alternator today in the 1994 K2500 Suburban. Old one had given up.
I still have the old CS-144. It has the same size pulley as the new one. Also still have the original CS-130 alternator. I can compare the pulley sizes and swap if necessary. What’s the proper size pulley for the 6.5? Where do I take the measurement?You did save Your 6.5 diesel pulley ?
IDR the diameter across the ridges of the 6.5 pulley, It may be 2-5/8ths inch, IIRC.I still have the old CS-144. It has the same size pulley as the new one. Also still have the original CS-130 alternator. I can compare the pulley sizes and swap if necessary. What’s the proper size pulley for the 6.5? Where do I take the measurement?
It must be smaller as the tach is reading much higher.IDR the diameter across the ridges of the 6.5 pulley, It may be 2-5/8ths inch, IIRC.
I recently bought one from Leroy Diesel, I’ll get a measure of it.
I do know that at 70 MPH that the tach is reading just about directly on 2,000 RPMs with 4:11 gearing, or maybe its 4:10, I cant rememer alla this.
Clearly the pulleys are not the same size in the photo. Furthermore, I know they are not the same size based on how far I had to move the tensioner pulley just to get the belt on.@Big T measure the diameter on the groves of the pulley, those two looked the same in your photo. the fans should be the same between the CS-130 and the 144 so you could swap them too. and iirc there should have been a spacer on the cs-130 that you can use for it as well.
I got rid of all my steel wheels. Just gave them to the tire shop when I had new tires installed on my Alcoas.Went to the auto salvage and purchased a set of stock steel wheels fo the 2000 K3500.
They all have some rust on them so I’ll buff the bead seats with a wire brush mounted to the right angle grinder, then, sand blast them.
I have a 40 pound pressure feed blaster.
Stopped at the only store that usually has sand but they are all out. Be at least a couple of weeks before they get more in.
I got a 40 pound bag of light duty and an 80 pound bag of medium grit coming from Amazon. Shipping is free. I should be able to get four wheels done with that.
