ak diesel driver
6.5 driver
Any ds4 engine I've worked on didn't have any marks
That little Vee mark looks like the left side of it is the straight line for a timing mark.since driving the 95 around yesterday and today, I now realize just how much louder the clatter is from the 93 with the newly rebuilt injectors. figured I would look at timing to see if it needs to be adjusted.
took a gander at the IP timing mark and looked for the center timing mark on the timing cover. this engine has a timing cover for a newer block meant for a DS4. looking at this pic, what would be the center mark on the cover? I can see the center (base time) mark on the IP.
on the DS4 timing cover you can see that tiny "V" shape mark just to the right of the IP mark and my blue paint mark I made for my reference last time I moved the IP. also that weird looking dimple in front of the bolt sticking out. does anyone know what the center base timing mark is on this timing cover? @Will L. @ak diesel driver
it just quieted down on the clatter when I pushed on the lever
only thing I could see was the fuel pressure gauge went down maybe 1psi when I applied power to it. no noise change or anything
The high idle solenoid appears bad. The internal to the IP cold advance solenoid appears working by the fuel pressure change. Engine off listen for a click when you apply 12V to it on the IP connector. Watch fuel flow in the clear line engine running: it's an insane amount at operating temp solenoid off. Cold advance solenoid(s) on the fuel flow slows way down. Last you should verify the switch for this in the t stat crossover is working. Should have 12V at the solenoids when the engine is cold. Offhand it's 600 RPM hot and 700 RPM cold, but check the sticker under the hood to verify. I sort of recall it kicks off at 140F.
Ar 45 MPH hold a steady throttle operating temp on engine. You should hear the IDI clatter. Roll some fuel into it and the clatter should quiet down as the precups get some heat in them. This is where the timing is correct done by ear. Now if you can't find this then try undoing the transfer pump 1/4 turn.
I had suspected this before when randomly while accelerating the engine would begin clattering very loudly from a stop. as well as on occasion would go into a loud clatter when cruising in town. a couple of times it was loud enough that my wife looked at me from the passenger seat asking what was that!! I would just let off the pedal and it would go away. it has not done this for quite a while, but again was random.It's possible the transfer pressure change has pinned the advance piston at max advance.
the solenoid won't bump up the RPM on it's own.
I'd recommend sending it to a reputable shop and have it rebuilt or purchase a quality built pump then the guessing is over.
Love the flow chart LOLIt’s running on a tired old engine that isn’t gonna be running a lot longer.
Leave it be and move on. If you can time it a little better- cool, otherwise let it ride.
Flow charts available:
