Goose57
Hi all just trying to finish up my Optimizer build but I can’t get a good compressor. Bought 2 new Murray compressors and both were bad, What  are the odds of that. Both of them started screaming right out of the gate when I jumped the pressure switch.
The first one I didn’t let it run long. Maybe got a half can of freon in after I pulled the system down and checked for leaks.First thought it was the clutch and coil causing the noise but when it drained the oil from the compressor and there was a small amount of black oil mixed in with the rest of the oil. That’s when I decided it wasn’t the coil bearing making the noise. Pulled the orfice tube and it was luckily clean. May it didn’t get to the condenser. New Evap. and condenser, dryer and orfice. Got a new compressor warranted from O,Reillys and made them give me some flush and the flush tool. Had to repair the flush tool because it leaked.
 Flushed the system ( it wasn’t very dirty) and pulled it down, jumped the pressure switch and it too started screaming right away WTF
Both of the compressors came w/3oz. of oil in them and I topped them off at 8 oz. the required amount as per the paperwork.
I let the second bad compressor run longer getting almost 2 cans in while trying to figure out what’s going on. In the above video the belt was chirping on start up without the compressor running and went went away when I disconnected the vacuum supply to the boost switch. Then when I jumped the ac switch it got louder. Strange
. The second video below is after I ran the compressor longer and the chirping turned to  screaming. Pulled the compressor again
 and the oil was a lot blacker but there was less oil compared to the first compressor. I did let it run longer so maybe the oil did get to the condenser. Both videos are of the second compressor only. Anybody have any problems w/ Murray (Four Seasons) compressors? Any suggestion on a different make of compressor they’re probably all from China. Maybe I’ll try a rebuilt one. Thanks guys.
