snarl95
If anyone has a starter laying about could you measure the bolt hole? Mine seem to be to large and allow the starter to get crooked.
I used the ARP bolts from Quadstar and they are good.I measured my spare unit and got 10.07 or 10.1mm. Ensure you use M10 Starter bolts. Quadstar sells ARP units (special run, not on ARPs web page) or NAPA has them too. Don't forget the bracket at the front though.
Don't try using 3/8" starter bolts because, while they'll thread in to the block (I know) and they will probably torque to 35ft lbs (they did) they'll probably strip out the block's threads (I got VERY lucky).
I got my ARP bolts from Summit racing, can't recall the part number but they came with some sort of spacer washer that one side was dished out. no instructions as to how the spacers went in though.I measured my spare unit and got 10.07 or 10.1mm. Ensure you use M10 Starter bolts. Quadstar sells ARP units (special run, not on ARPs web page) or NAPA has them too. Don't forget the bracket at the front though.
The side of the washer that is dished goes to the bolt head. Use anti seize between the washer and any surfaces the washer comes in contact with.I got my ARP bolts from Summit racing, can't recall the part number but they came with some sort of spacer washer that one side was dished out. no instructions as to how the spacers went in though.
When I had the no start on the ‘94, I had no time to test to make sure it was it was the starter. I just ordered the PowerMaster starter and installed it. It worked as soon as it was installed, so my conclusion that the old starter failed was correct. Old starter sat in the PowerMaster box on the passenger seat until I dropped it off at Napa this past Saturday.I got irritated and junked all of the GM 6.5 starters I had here
