/\_/\_/\_ WHAT
@Will L. SAID _/\_/\_/\
On the subject tangentially, a parasitic draw was found by way of direct short and small fire.
With the hot charger starter hooked up the volt / ammeter gauge caught fire behind the dash. It could be seen through the plastic dash. A quick unsnap and a puff blew out the fire. It appears for quite a while the ammeter shunt was grounding the connections to the dash frame.
There is a master battery cut out switch in the driver's step well which I threw but the starter charger was still pushing current. I made sure the hot leads were clear and threw the power back on and the starter charger went back under load but not as hard.
The voltmeter through the USB ports showed the batteries taking charge faster
Since my starter charger is old school 14.7 2/35/200 Schumacher. It will push 15.3 volts which will damage AGM batteries by induction boiling or heating the electrolyte. So I never let it push more than 14.4 volts before I throw the key to start. It almost always will start unless I previously had rn the batteries low by cranking. It can reach 14.4 without sufficient reserve capacity in the batteries.
Once it starts I use the duai alternators to further the charge but it takes a lot of idling and driving to restore lost reserve capacity unless I force " hard charging" by jumpering in a load or with a load through the inverter to cause the regulators allow maximum amps.
My alternators (dual) are custom 240 amp each, but they will only push a charge if another load forces them to.
Now I understand why the ammeter was reading such strange numbers and the service side batteries were not charging.
My AGM batteries are flooded, so they charge fast and have about 5 percent higher reserve capacity and when close to full charge when I shut off the key will read 13.2 volts and settle to 12.8 to 12.7.
Slowiy without the volt / ammeter gauge those numbers are returning, and for the first time in a long time it started using the batteries after shut off.
After I service the batteries, it it going to take a lot of running the engine with a desulfator to get close to spec reserve capacity back, but I I think and hope that was the culprit making the batteries weak.
On dieselplce I found a thread with the similar issues I was having where the guy described the same thing with it would start using a starter charger but not batteries. He replaced the batteries and that ended it. My batteries are relatively new and after some service and care I can bring them I believe.
All this started from changing a fuel filter and difficulty sealing the water sensor leaking and the extended cranking that caused depleting the charge on the batteries. At least I found a major root issue that has been perplexing for some time
