Yes, I am aware of what the original unit is and how it works in vans ve trucks, vs older 6.2 trucks, etc. my point is the amount of water the filter can stop is exceeded by time the water triggers the alarm. The biofuel is worse for the issue. Original diesel fuel never had algae issues but new stuff does- ESPECIALLY bio fuels because the algae survives in the suspended water, it does not survive the straight hydrocarbon fuel. Just offering info and options.
If you can do the research to learn what everyone else is telling you and doing it to their trucks for reason- if you don’t want to remove the subpar filter usit and replace it with something better-that your decision.
You said the problems began with the leak. You tried to bubble gum it together (which we all have from time to time) and you still have the problem. The root issue seems pretty obvious. The verification test given by Stanandyne and by GM is the clear return line. If you don’t want to do that, your call. Best of luck to you in solving it. Let us know how it turns out.
I don't run biodiesel. On occasion I might top off the tank with b20 if it is cheaper. As I said I run r99 or r95
R99 alleviates most of the issues that were present with the biodiesel blend. R99, unlike biodiesel, is hydrogenated, meaning the oxygen molecules are removed during the refining process. This is a significant advantage for storage and cold weather performance.
There are none of the water issues to deal with using R99 that were problematic with biodiesel. Water that was present in biodiesel had to be treated to displace the water and prevent it from entering the diesel engines and being burned.
They call it "biomass" but it is truly a different product.
I do run a biocide about twice a year. The DS4 - especially if run with low fuel pressure will collect algae in the optic sensor timing wheel cavity, and then it is bye bye IP
They came into the shop all the time for rebuild with wheels damaged so bad the rebuild was too costly. Between burnt up fuel solenoids and screwed up optic sensors and wheels they were not economic rebuilds.
I don't disagree that filter is crap as an OEM part but, then again the entire 6.5 is.
A Vortec, 4 bolt main built with 10:1 corvette pistons supercharged is standing by to go in the van to run E85
I agree there may be an air leak in problem, but I am not interested in burying money in the diesel soon to come out.
About the same time the leak stopped, the extended cranking due the air, had run the batteries down, and the starter was cranking slower even when I charged the batteries fully.
On E85 that filter style would be fine
So now I just swapped the starter, but taking a rest because the batteries are needing a charge
Trying to start it the bendix and solenoid went out, so I had no choice anyway.
I need to solve this problem first, and if it turns out to be the CPS or IP the diesel Era ends and it is coming out for the vortec instead
