Goose57
Thanks dbrannon79, yea I’m not sure it is not the injectors I didn’t check them. Pro Tech Diesel in MT checked them and they were recommended from this forum. I talked w/ the guy and he said he didn’t have to do anything to them they were fine. I believe MrMarty said on here that he checked this guys work by checking the Inj. he sent them w/ a tester he had and they were all good. Yea like I said I’ll probably try my old pump but maybe I’ll try doing the timing again especially since I haven’t heard if it’s set right after posting my engine data from the scanner. I would feel better getting an IP dtc before pulling the pump. Does anybody have any suggestions on where to have a rebuilt IP checked out if I go that route. I bought the pump from Quadstar back in early 23’ I’m sure it’s out of warranty but I will try check with them also. Thanks again.
