dieselolds
If my engines start to leak from those adapters and cause grief I’ll just go with the straight up and down filter.Like was stated earlier it’s less leakage points to worry about in the long run.
Are you able to do that with a GMT400 4x4?If my engines start to leak from those adapters and cause grief I’ll just go with the straight up and down filter.Like was stated earlier it’s less leakage points to worry about in the long run.
It has been done before on a mid or early 90s K1500 with 305 or 350 that belongs to someone my father knows.Seems there is enough room to just install a straight up and down filter.Are you able to do that with a GMT400 4x4?
On the 2wd I used to use the 2 quart filter.
Will: I think (could be wrong) the part on the 90° can be removed and installed into the block.
Just swap these two:
I was going to suggest trying that. I thought I remembered doing that, just a few short years ago.
If ever have to take the adapter off the 1994, I might remember to look into that.It has been done before on a mid or early 90s K1500 with 305 or 350 that belongs to someone my father knows.Seems there is enough room to just install a straight up and down filter.
I looked up the thread pitch on the filter. it shows to be 13/16 - 16. iirc 1/2" npt is 14 thread pitch.
Dont sound too bad.Well folks guess what.... I finally got over my chickening and went for it! the 6.2 runs.
for about the 4th or 5th time I checked and verified fuel to the injectors would stop with the loss of power to the IP then went for it. I had my wife help me record a video, didn't get to record myself starting it on the first run but had her record the second round. Didn't want to run it very long with no cooling system on it so I cut that short.
oil pressure stays about 40 on the gauge and I thought I saw a little oil in the turbo inlet but I will pull the upper intake and verify that since the inside was clean before I started it. the engine is showing a little blowby but again didn't run it long enough to know how bad it really is. No knocking that I can tell but at idle it kinda jerks around and smooths out with a slight increase of the throttle though I didn't want to romp on it with my make shift a-frame and stand setup.
tell me what yall think. is it worth it moving forward, and what would be my next steps? maybe rig up a cooling system and run it longer?
I will hopefully find out soon!You sure it was exhaust and not steam?
