CursedH1
Active Member
- Messages
- 76
- Reaction score
- 239
I eliminated the tee. The adapter I cannot eliminate as the probe is actually long enough to go to the bottom of the thermostat housing even with the adapter in place.
Yesterday's drive to the gym and back (my debugging trip) was MUCH better. The disengagement was still longer than I'd like but MUCH better than with the tee there. My max temp yesterday was only 201 so I have a bit of headroom on the engagement screw, so I went ahead and bumped it up a smidgen and will test today.
As for the fan - the Dmax fan is significantly heavier than the OEM H1 fan. A PWM system works by modulating the ground/earth side of the circuit so that its getting 12V+ but intermittently, like someone is tapping on an old school morse code telegraph machine. With the mishimoto I don't think that it was getting enough juice at the lower engagement temp, but with the flex-a-lite I can definitely tell with my throttle response when its barely engaged - especially on the cooldown.
The Flex-a-lite has a manual override switch as well that locks it up 100% - I'll see if I can figure out a way to measure its cool down. I also have the switch in the cab wired up to completely shut down the controller so I could measure how long the clutch stays engaged with absolutely no power whatsoever being applied.
(long slopes in the middle were while the truck was parked)
