Tinker
Active Member
I installed a Plews-Edelmann steering box a couple of years ago to replace the sloppy and leaking factory unit. I've put somewhere around 10k mi on this box since installing and @ak diesel driver had some questions, so I thought I'd write up a quick post.
The box itself has performed well for me. I've had no leaking, the outside remains completely dry, and the box does not have any play. Overall, I'm very pleased. The unit removed a good amount of slop from my steering. What remained was from the rag joint and the tall bias ply tires (7.5x16), which are a little tipsy on asphalt.
I also just replaced the steering shaft with a u-joint unit from Cunningham Machine (https://cunninghammachine.com/1988-1994-chevrolet-gmc-truck-steering-shaft/). I'm mostly pleased with that shaft. It didn't require any modification (I've heard that the Borgeson unit requires some cutting, though that may have changed) and was about $100 cheaper than the other options. My only complaint about this unit is in the design of the fastening hardware. They chose to use a set screw instead of a pinch bolt at the box end and 2 set screws instead of a shouldered through-bolt/nut at the steering wheel end. I'll be keeping an eye on those for wear and loosening.
Between this and the Edelmann box, my steering is now pretty solid.
