Big T
On the ‘94 K2500 Suburban, I have the 2nd Generation (post SKB) air intake. There is a simple 3/4” diameter hole in boot for the hose from the CDR and it is egged out and leaking. I would like to address this as I do the CKO ProVent install. Existing fitting is a 3/4” straight barb. Looked on Amazon last night and found a heater hose 90 degree barb fitting by Gates, but it provides no OD dimension. Presumably it is 5/8”.I think the ideal solution would be a threaded reinforced plastic fitting pushed through from the inside and locked in place with a plastic nut, then an 90 degree elbow threaded onto that.
