Rutjes
Member
Hey guys,
My current trailer hitch is kinking the frame on my '98 K1500 so I'm designing one of my own. I'm using my Iveco Daily hitch as a reference. Here's a 3D drawing of the design I have so far:
I plan on removing the stock X shaped crossover and replacing it with a custom made one as seen in the second drawing. The side plates will be laser cut from 10mm thick steel (about 3/8"). I did not draw them in yet, but there will be gussets between the rear crossmember tube and the tube that holds the hitch. The bolts highlighted in green are where the leaf spring hanger is mounted, I'm re-using those holes. I'm thinking of using M14 bolts. The crossmember tubing is 80x40x3mm and the tube that holds the hitch is 60x60x6mm.
Will adding a 10mm plate between the frame rails and the leaf spring hanger cause any problems? I have come across Rust Buster frame repair kits that do the same thing, but they are 4.78mm thick (3/16"). What do you guys think, will it be fine or will it cause binding in the hangers or shackles?
