Will L.
I’m with warwagon- I still wonder if the heads came off too soon.
Blown gasket should have hydro locked engine, overheated drastically (which would be excessive heat from heater core not less), finally exhaust gasses in coolant system is the test to verify. Pressurized coolant hoses so the cap keeps popping overflow or radiator hoses blowing off.
I hate to say it but I think you just had an air pocket. Especially with the heater core is higher than the engine.
Did you do a combustible gases in coolant test?
