Doug said a key point that I thought and didn’t say, should have emphasized.
Why I said the cooling tablets:
I asked how much coolant you have to add and your answer was basically so little coolant that I almost wouldn’t worry about it.you are not dumping a ton of coolant in there constantly. They are telling you switch to oil changes at 1,000 mile’s because you are doing a flush of the system basically.
Yea the oil in there now is bad. Yes it is showing bearing wear and all that. But 260,000 miles on this engine that we know most likely they are not good candidates for a rebuild. With the expense is takes it’s better to trashcan the GM unit and find an optimizer to put money into. So who care if the gm block blows up.
If you are in a situation where truck breaks down on the road it could be dangerous for you- like I have a friend missing right leg- he can’t walk 5 miles so for him it could be deadly. For me, it is gonna be a sucky day because my plans for 1 day get ruined while I walk a few hours until cell service then wait for a tow truck. Maybe use a sick day at work.
I pulled out my optimizer and tore it down because it had low mileage and I knew it was a great candidate for rebuilding. But if my nephews 1988 6.2 starts to go- we aren’t pulling that engine until it is fully seized and has a couple rods laying on the ground. Get every last mile out it. Rare, but I have seen condemned engines run for 40,000 miles before actually dying. Most of the time they go about 5,000 miles when getting early warnings like this. But when dealing with a block not most likely to rebuild- might as well drive it unless you are in a dangerous area, or risky health condition.
You are talking about leaky ip- we all are seeing coolant in the oil- not diesel fuel.
And btw- I would be putting in low cost oil not synthetic anything. Yeah- run it for 1,000 miles and spin on new filter. Probably do that for next two thousand miles and would not bother with sampling- this is a condemned engine at this point. Don’t waste money on trying to get longest life from it. Then when you get close to the 3,000 mile level and it’s about time for the next oil change- THEN send in a sample.
Obviously you are watching for any loss of coolant along the way. If you start adding coolant frequently then expect engine death soon.
If money is a situation where you will probably get rid of the rig once engine is gone- or you’re not gonna put a new one in the truck but have to keep this running long as possible at lowest cost possible- then the right answer is pull both heads, new gaskets and diy the brass sleeves. Ignore bottom end keep running it.
260,000 miles on a truck that didn’t get the life extension tactics applied until 200,000 mile mark is not gonna make it to 350,000. Your shooting for 300,000 target. So running say 30,000 miles on bearings half gone- so what. Starts blow by soon- so what.
Other than doing a few oil changes at 1,000 mile mark and adding those tablets at this oil change, I would not spend an extra dime on longevity because it is looking like it is done soon.
If this engine were a candidate for - or you have to make it work because of money- yes do all the testing WarWagon is saying to. Otherwise- meh.
I once had a gm inline 6, 250 cid gasser. Head cracked and was sipping coolant like this 6.5 seems to be doing. I was broke and the roof of that car looked like roof of my home if ya get what I’m saying . I would change the oil at 1,000 miles and kept the old oil in a couple glass pickle jars. Old oil filter stored so it would drain out inside the new filters box. The next month was about 1,000 miles and the coolant separated from the oil. The filter dripped dry. That oil and filter went back in the engine and what came out sat there the next month.
About 8 weeks into this the head crack got bad enough I removed the pushrods to the bad cylinders valves. Dropped the pan and pulled that rod/piston. Popped the pan back on.
Still had to keep cycling to oil because of coolant contamination- which since only 3 months of winter here means cold enough- most the time was just water in the system- not spending money on antifreeze.
No, that engine didn’t make it super long- only about 35,000 miles, and i think I only bought 2 more qts of oil and never another filter. No more spark plugs or anything. Rented mule treatment. But money saved went to a better engine.
In your case the tablets are a worth while gamble. Not much else if ya wanna just push it. If ya wanna tear off heads- don’t buy tablets yet.
