It's a dry heat they say! we start out in the dehydrator in the morning then after lunch the convection oven kicks in to high gear.Fixed the one left turn signal bulb:
Didn’t want someone to nag me with a honey do list. Enjoying single life here for a week while my wife is in Austin area of Texas, undoubtedly broiling.
Unlike my K2500 Suburbans that use ATF in the transfer case and transmission, the 4Runner uses 75w90 synthetic in the transfer case and synthetic ATF in the transmission.The way the two housings mate almost makes me think there was no need for seals on the shaft! just a gasket to join the two and have the extra fluid capacity for both units! LOL
I used the port on the passengers head for the temp gauge. not sure if there is any other water ports on the heads. I have that 6.2 on the stand I can rob one of the block off plates and thread a port on it. not sure if the plate alone is thick enough to tap threads into though. I might have to take it to work and have a bung welded into the center.@dbrannon79 no, above the t-stat in its housing not a good location. Is there anything in the passenger head rear sensor port? If not, use that. If there is, yeah, tapping the passenger rear block off plate is a very good option.
Should really do some reading over on HID Planet forums before you go dropping those bulbs in halogen housings. You are actually blinding everyone else on the road with that setup and real projectors will give much better light output for you too.
Bro they’re fine. Best lights I’ve ever had. No one is giving me the Hi beams when I’m driving. If I wanted people telling how I should live my life, I’d stay in California. Wait….Should really do some reading over on HID Planet forums before you go dropping those bulbs in halogen housings. You are actually blinding everyone else on the road with that setup and real projectors will give much better light output for you too.
BTW they are specifically not the halogen housings. Halogen housings have ribbing in the lens which scatters the light. These are euro clear lenses. The Lo beams have a cup over the bulb so they don’t burn the eyes of oncoming traffic. These were the housing style and lenses recommended by people here for HID lights.Bro they’re fine. Best lights I’ve ever had. No one is giving me the Hi beams when I’m driving. If I wanted people telling how I should live my life, I’d stay in California. Wait….
