Husker6.5
It "knows" to turn off (or on) because it has a tilt switch built into it.
That tilt switch is as old as the truck, I wonder if it's a mercury filled switch like the old HVAC thermostats of that era!It "knows" to turn off (or on) because it has a tilt switch built into it.
How’d that work out ?I’m going Marty on oil leaks…Redid the valve cover seals on the 2005 Honda Accord to address a persistent and annoying leak at the passenger side rear corner. Went with the FelPro gasket kit vs the Honda I used before which did not work and cost 4x more. I put a small bead of Honda bond all along the outside sealing surface of the cover and let it sit for 30 minutes before installing it. Now I’m letting it cure until tomorrow.
Patience! I’m letting it cure for a day.How’d that work out ?
My oil leaks is cured except the small tell tale leak at the front of the pan.
Now that I know that I could pull a couple of bolts and lower the front differential and the pan will then come out, I guess I could put the truck back in the shed and fix that seep too.
I’ll wait until tomorrow and see how I feel about it then.
It’s loose. Need to tighten up the bolts. Also discovered the Lo beams and running lights are not working, but Hi beams and runnings lights do work. So I’ve got some troubleshoot to do.That rear bumper and wench battery tray is kinda leaning. backed up into too many of the neighbor's trash cans ?? lol
www.instagram.com
Failed. After putting about 25 miles on the Honda, found a spot of oil in the garage. I’ll go through it. Thinking it’s down to a cover plate on the timing cover, or the timing cover itself. Either way, both are decent jobs. The leak is slow and I do not put a lot of miles on the car, so I’m going to punt for now. Many more important things on my plate.How’d that work out ?
