All truck pullers must have a means to kill the engine in case of engine runaway. The way P Pumps are designed plungers move up and down inside cylinders (barrels). Throttle on a P pump engine is accomplished when a rack moves with the throttle and governor to rotate the barrels. That exposes ports to different area of a helix which changes the effective stroke of the plunger, and varies the amount of fuel injected per stroke. Fuel lubricates and cools the plunger & barrel, which are an extremely close fit together. If any dirt gets in the fuel pump or if a plunger seizes to a barrel, you will lose that one cylinder, but the other 5 will be running at whatever throttle position it stuck in. The rack can't move the others back because of the one that seized. The governor is now out of the equation. If it stuck wide open and the engine made 600hp, you would have a 500hp runaway with rpm's going to infinity. The only way to kill the engine is starve it for air or fuel. Fuel would take too long. Pullers use air shutdowns. I found a 3-1/2" diameter aluminum throttle body from a Hemi in a junk yard. I hacked it up, welded a V band flange to it, and mounted it to my intake. I tried several mounting versions to make it fit under the hood, and have a straight cable pull to close it. I wound up modifying an
View attachment 82295View attachment 82296View attachment 82297View attachment 82298intake elbow off of a 24 valve Cummins, and fabricating the rest.
