The fan is the Delco unit from RA. And the controller is the Hayden with the screw in probe.I will have to look at mine and see which wires were used. I know only two are used on the clutch connector. one is ground and other power from the controller. I did find out from experience that the wire colors are different between brands of fan clutches. I at first bought an off brand one then later ordered the AC Delco one.
which controller are you using? Hayden makes two of them. one with a thread in sensor and the other with a probe that you can strap to something.
Yup, I too am quite efficient at derailing the train from the threaded tracks.STICKY!!
STICKY!!
STICKY!!
Well, could a moderator do “qoutes” of the threads that have the pertinent info and make a locked sticky of that? 17 pages and counting and many non crucial comments- a ton are mine here don’t need to be in it.
I need to look at my fan. Probably won’t be till later tonight after work. Iirc I think I posted how I connected mine On one of the threads I started. I’ll have to look for itThe fan is the Delco unit from RA. And the controller is the Hayden with the screw in probe.
Is it correct that the blue wire from the fan clutch is the one that needs to be grounded ?
Several of Mine can be eliminated too.
Thank You very much.I need to look at my fan. Probably won’t be till later tonight after work. Iirc I think I posted how I connected mine On one of the threads I started. I’ll have to look for it
just to be sure I’m reading you right…. Looking at my connector pin A (blue) will be ground and pin B (red) is hot 12v+
The clutch is from a 2010 express van 3500 6.6 d-max
this connector isn’t labeled with any pin lettering or numbers. Cheap Chinese made I guess lol
Okay, thank You very much. The red and the blue are the two end units within the connector.I think so, it should be the two pins on one end of the connector iirc I know I had posted a pic of my connector here somewhere.
I’ll get to the garage tomorrow and see which wire from the controller I hooked to the AC compressor clutch.@MrMarty51 how did you wire the controller so the fan turns on with the A/C? Did you find a magic trinary switch or splice into one of the a/c system pressure switches?
Hello, Apologies for the thread necromancy (I run the Hummer Network Forums so I know how it can be annoying) but I feel like this is an applicable update to the thread as I have a question for the 6.5 gurus.
This past weekend I finally added the electroviscous fan clutch to my H1's brand new P400 (well, 2 years old now I guess). Going off of the feedback from a very smart guy I know who tried this same setup on his H1, the Hayden on/off controller just doesn't work for our rigs as he indicated that the on/off nature of the operation just wasn't ideal. So I went with a Mishimoto PWM fan controller for myself. I put together a harness that included an A/C pressure switch tied in with a manual override switch in the cabin for an Auto/Off/Override functionality where I can manually turn on the fan. I put the temperature sender in the thermostat housing as it was easily accessible and didn't require that I drain the coolant in order to install.
I've taken 3 trips so far with the fan clutch operating. I've adjusted it a few times but am not happy with its operation. I have Torque logging the data and as soon as I have enough, I'll run it through some visualizations however I think that I need to find an alternate location for the temperature sender. The engine will warm up and be fine until about 200'F on the ECM sensor. I've had the fan come on at 197'F and at 204'F so I'm guessing that the 200'F is about where it starts to engage. The problem is that the fan will stay engaged (evident by the deafening roar) until the temp is well below 175 again - which, if the PWM controller was working properly - shouldn't be happening. I think the issue is that the coolant temp level that the controller is reading - thanks to it being in the top of the thermostat housing - is entirely different than the temp reading I'm getting from the engine computer. I was thinking about, and @Will L. recommended putting a tee at the top passenger side head where the existing temperature sender is for the computer but others have indicated that this is not a great solution as the flow up into the tee will not be great and it could collect sediment. Is there another pre-tapped location in the P400's that I could use to put the fan controller sender?
