Here's a list of what I have planned for your pump.
*reconditioned housing with sleeved advace piston bore and new throttle bushings.
*custom resleeved H&R (.350)
*smooth lobe camring
*cryo treated campin
*3/8 inlet nose cone.
*4500rpm govenor
*ceramic rollers
*larger leaf spring
* hardened T/P for ULSD
It will obviously get all new bearing and seals. And every is ran through a ultrasonic cleanner.
No one in the industry is refurbishing H&R like I will be. It's the closest thing to a NEW H&R you can get, but less than half the $950 cost of a NEW one. The big differences between mine and CDD refurbished H&Rs is mine uses
NO hard chrome!! The problem with that process is the hard chrome can seperate and destroy the pump.
To avoid that issue I have the factory sleeve pressed out and a new undersized sleeve is pressed into the head assembly. Then the rotor diameter is adjusted to fit the new sleeve.
Unfortunately I haven't found a way to machine the plunger bore for larger plungers... yet. So In order to step up to .350 or larger plungers a rotor is taken from a AG pump and sent out with a 8 cylinder head. The larger plunger rotor is machined to fit the sleeved 8 cylinder head giving us larger plunger options that never where available on a 8 cylinder DB2!!
The problem is finding these bigger plunger pumps. .350s are EVERYWHERE, but they are many used in JD tractors and that drives up the cost. .370, .390, and .450 rotors are extremely hard to find but they are out there. I have a .370 waiting for my build. There is also a .450 sitting on the shelf for our resident HP record holder.....Im sure you guys can guess who that's for.
