Hi Will L. Nice to meet you. I have a engine driven compressor and a roof vent (80's style ) I'm in New England and as my truck is "open" to the public ( order-serving windows) a rv type a/c would be useless. What changes would you make? I rewired the entire interior with 12-3 and 14-2 wire and 10 traditional plugs with a main 14 slot breaker panel. I also have a 7kw rv generator.Welcome. I don’t have schematics, but used to be a Mac Distributor some years back-.If I’d known then what I know now, the changes I would have made...
I don’t see any rv a/c-heater units on the roof. Is that yet to come on the build of not needed where you are?
Hi Will, sorry I didn't respond earlier but its a busy week. Lots of cookouts ( we do whole pigs, ribs, chicken, seafood, steaks, burgers and dogs and more) For an Italian restaurant we are very versatile. If you watch Restaurant Impossible with Robert Irving we have been on his show three times in the last year and one half. If you're interested, we are Perella's Restaurant, Warren, RI.I am dumb sometimes (the rest of the time I am sleeping). I didn’t pay attention to the windows you added in.
I thought you turned a food truck into a Mac tools truck and was going to sell tools. Didn’t realize you were going the other way! Haha
GOOD. Money first then product! Tools are the other way around, and it sux!
The fact that is was Mac, nothing to do with the truck schematics, parts, etc.
You have a Union City Body co. Aka Coachbuilt on a GM chassis.
I had different body mfr. so not familiar where to chase manuals for it. I will say when you find one- get it. Rare as hens teeth.
Many of the food trucks out here use the big motorized vent on top. If you need more volume later- look into that.
Post pics here of the engine so we can point out things that need addressed.
like mentioned just leave them loose and when you crank it to start, as the fuel spits out (will be a tiny amount) tighten them 1 by 1.
There are several engine killers for this rig that have no warning before letting go:
Engine oil cooler lines rupture- get a new set from Leroy’s Diesel or have hydraulic lines made to replace them.
Harmonic balancer failure destroys block/ crankshaft. For your use- get AC Delco. They are good for 100,000 miles or roughly 30 years if low mileage. The little rubber piece fails with age or wear. Get new belt drive at same time. If the front main seal is leaking, change it at same time, it is under harmonic balancer.
Add a clear line on the ip (injection pump) return line. This is for instant diagnostics of air or other contamination in fuel system. Water is massive damage to fuel system. Adding a fuel pressure gauge to the line just before the ip so you can read it when driving. Low fuel pressure ruins the ip quickly. Depending which ip you have DS4 is electronic and uses fly bywire throttle, it needs 8-14psi. The db2 is fully mechanical and uses Linkage/ cable to control throttle, it needs 2-5psi.
All rubber fuel line needs to be sae30r9. The clear tube off the ip I recommended would need to be replaced every 3 years or so, but is $5 and 5 minutes to replace.
My Brother in law runs Buddy V’s here in Vegas. I can’t cook but to save my life, but sure am good at eating!
Good to hear you know your industry.
Do you know what chassis it is? I’m assuming P32/42 Chassis.
View attachment 65219View attachment 65218
Hi Will, Nice to meet you. The IP is fine , it's the fuel line from the pick up pump ( the one that mounts on the frame and looks like a fuel filter on a gas engine - left side just aft of the batteries) to the fuel filter/ water separator that is my problem ( the IP is manual , on the left - middle side) that is giving me all the problems. Last winter it split at about middle of the intake valley pan location and when I attempted to start the engine it spewed diesel fuel . I got the old gas line out but to properly install a duplicate line I have to "lift" the IP lines to cylinders 2,4 and 6. Instead of screwing with something that is working great I was wondering of I can two part the line to make the bend ( the line runs from the back top of the block down the right side to the right front of the block down to a rubber connection line to the pick up pump) instead of trying to force the longggggg single line under the IP lines and down the block. I remover the alternator and the holding bracket, belt tensioner (which was frozen up!) and still did not have enough room to get the whole old piece out. Broke it in half! So, what do you think? Thanks for your time and interest. DanWow. That sounds like mechanical lift pump (pick up pump) bolted to the engine on the front passenger side? Or is there and
really hope that is a mechanical injection pump...
You might even have the old school brick fuel filter...
we really need pictures of the engine- multiple, from different angles..
