Got a problem 94 6.5 td
Problem: Just picked my truck up from getting the heads rebuilt. Drove it 3.5 hours ( 60 % hiway / 40 backroads ) 100 miles ran fine, no problems,got home ( last leg of trip was on a bumpy 5 mile dirt rd. Turned it off after turbo cool down...will not start now, cranks fine, no glow plug indicator light ?, just cranks
Demographics: :
- Year: __1994____
- Truck model and class (ie: c2500) _2500 suburban________
- Automatic or Standard ___Auto_______
- Mileage: (indicate miles or km) _156,xxx________
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ___________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ____f / turbo__________
- Ambient outside temp: (indicate *C or *F) __________
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) _#1____
- What fuel additives are you using? __None_________
- Where are you located? _____CO________
General maintenance: inspect and evaluate the condition of each. When were they last changed?
- Air filter ____2mon_____
- Fuel filter ___2mon______
- CDR Valve? ___?______
- Coolant – last flushed/replaced at ____2 weeks_________
- Oil – synthetic/regular, changed at __156.xxx_________
- Batteries – state of charge, (matched set) replaced at :were working
- Battery cables and grounds (removed, cleaned and tightened): _____Yesterday_________
- Glow Plugs - how many miles on them? ____60,000_____ What type? _____________
- Injectors - last changed at _______?________
History: (Describe how the problem first appeared.)
- What were you doing when it happened? __trying to start it____________
- How was the truck running fine before this problem appeared? __Just fine___________
- Has this problem ever happened before? ___No____________________
- Describe any related factors that might be part of the problem. After this happened. I checked batteries and found the neg. cable from 2nd ( passengerside) battery was not connected to ground
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __n__ And? ________
Diagnostics:
1] Starting:
1a] Does the engine start? ___n______
1b] Does the engine crank over? ____y____
1c] Are your batteries fully charged? ___?______
1d] Have you removed, cleaned, and tightened all battery connections? _____y___
1e] Does your Wait to Start light come on for a time? How long? ___?______
1f] Does your glow plug light come on? ____n_____ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? _Y, dark_______
2] Fuel Issues (if not running):
2a] Can you hear your lift pump working? ____n________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ____y_____
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ___intake________
3b] Condition of Extension harness (if used) Vendor or Homemade? ___good______
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _____good____
3d] PMD Make: ___________
3e] PMD Age: _____________
4] Stalling Issues
4a] Do you experience stalling only when hot? ____n________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ____n__
4c] Does pouring cool water over the IP seem to help with restarting? ____?_____
4d] Is stalling momentary (engine recovers)? _________
4e] Does SES light come on when engine hiccups? _________
4f] Does cruise control quit working when engine hiccups? ___________
4g] Does re-starting seem to reset engine, restoring cruise and power? _________
4h] Changes to dash lights or instruments during stalling events? ___________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? __n_____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _____n_____
5d] Excessive white smoke from exhaust on cold start? ___n______
5e] Excessive black smoke from exhaust under hard acceleration? ____n______
6] Performance Issues
6a] Do you have gauges? _____n______
6b] Maximum boost under load? ____________
6c] Have you added a performance PCM (reflash) or Chip? ____n__________
6d] Have you changed exhaust / downpipe / crossover? _____n___________
6e] Wastegate – mechanical or vacuum? _____Mech_________
7] Temperature-related Issues:
7a] Single or dual thermostats? ______s______
7b] Have you replaced them lately? Manufacturer of replacements? __y, 100 miles , NAPA_______
7c] Have you pulled and cleaned Radiator and coolers lately? _____n_______
7d] Have you replaced the fan clutch? Manufacturer of replacement? ____n____
7e] (winter) Have you tested your antifreeze? Good to what temp? ___y_______
7f] (winter) Are you using a winter grille cover? ____n_______
List and describe any other factors which are not addressed in this checklist. .
_________________________________
