aussie burb
- Messages
 - 16
- Reaction score
 - 11
replacrd and relocated pmd and now very hard to start if it starts at all.lots of white smoke and no revs .help!!!!!
Oh, and my understanding is your wonderful continent does not inspect that engine for using the ds4 injection pump.
I would remove and sell the ds4 and related components and install a db2 in its place in a heartbeat. Want more power- db2. More mpg-db2. Lower cost of ownership- db2. Less breakdown- db2. Easier repair when it does break down- db2. All parts still available and will be for next 2 decades according to AM General-db2. No pmd forced run away- db2.
better control for wmi injection-ds4. So my score is 7:1.
yes, I am biased.
We have a start of sorts.i used small amount of starting gas and it running. Still huge clouds of white smoke and no revs.decided to let it idle and warm up as the engine warmed the white smoke went away.as soon as pushed gas pedal down slight increase in revs but lots of white smoke again would bad connections be causing this if so how to test and FIX??????Those pins are a VERY common nightmare that people think they fixed, but still bad connection.
I can’t remember any specifications- hopefully someone here can post-
You should add extension cable and use multi meter to test the signal going through the ip cable and through the extension cable to be sure you have it ok. Right now the Vegas odds are 92% that is your issue.
the problem here is there is no corner parts shop for these engines.it takes 2 weeks to get parts from the usStarting fluid will burn the Glow Plugs in this truck when the GPs are glowing.
You really need to get a good extension cable, there are a lot of chinese made that is not good.
They pass electrical test but will not make the proper contact.
The PMD is also another issue. They can be DOA.
The day assuming "new parts are good" is long gone.
Now, you have to really test the parts, users have become the Quality Control Inspector for the companies.
Will check tomorrow thksOnce again sounds like air
when i start the engine cold i always wait for the glow plugs to go through the cycle.do any of you guys know what the volteges etc should be at the connecter that goes into the PMD . mine shows A green 0 volts B red 0 volts C black ground 001omhs D pink 12v E red 5v F ground to ip checked with ignition on engine not running if anyone can point me in the right direction with this problem i would be very grateful.because of this i have no transport and i live out bush so you can understand my problem. thanks guysI agree about the air.
on the glow plugs, and freezing temps: when I say cold engine i mean it hasn’t tan in the last 5 hours. I live in Las Vegas- a hot desert climate. It can be 80f degrees outside and these engines still have the ‘wait to start’ light come on because the engine coolant temperature is cold enough that it will still use the glow plugs as a starting aide. It does not have to be a cold winter day to require the glow plugs.
When you turn the key on you have a light that says ‘wait’ or ‘glow’ or something similar. Do you wait until it goes off before cranking the engine or do you just inseet key and instantly turn it and start like a gasoline (petrol?) car?
`im going to right nowDid you ever check for air?
