My fuel milage was around 14mpg. :rolleyes5: I hate to admit it because some are going to assume my IP was destroyed by the wvo, but I had several symptoms of a worn IP and just had it changed last week. I let everyone know if the milage changes, which I suspect it's going to. Here are a list of several early warning indications I got before that have since gone away.
1) I couldn't hold the throttle down and hold the rpm at a steady 2000. It wanted to either stay at idle or run up towards the red line.
2) Above 45mph the truck didn't want to hold a steady speed with either my foot or the cruise control. It either wanted to slow down or accelerate. The only time it would hold a constant speed was going up hill.
3) At start up the engine was extremely loud. It had what I thought was a normal diesel clatter. This is now much quieter at start on both cold and hot start ups.
4) Once the engine was at normal operating temperature and was shut down it wouldn't want to start. It would crank over and once it did start it would barely catch. On wvo it would start a little quicker but I believe this is because the wvo is a little thicker then the diesel.
5) All my settings are still factory. When I went WOT black smoke would roll. Again I thought this was normal. The new IP while still putting out black smoke at WOT it's not near as much.
6) On a mildly cold start (40 degrees F outside) I would get the common white smoke. With the new IP it's still there but not as much.
All this being said, I have read on here that the worn pump is providing more fuel then commanded which is what causes all these symptoms. If these are what you are seeing then I suspect you are dealing with the same thing as I.
Something else I found interesting that the guy swapping my IP's out told me about. When my old one was taken off the bolt that comes through the front had been worn and wobbled itself sround produceing a mushroomed head. This make sense to anyone?
