CursedH1
Active Member
- Messages
- 52
- Reaction score
- 156
Hello There,
I am assembling the components to install a fuel pressure gauge into my H1. I've got a mechanical lift pump going into my DS4 so I'm really keen on getting a pressure reading going into the IP. I have a FTB mod already installed.
I've found a stainless AN6 Tee that I can use to put on the inlet port on top of the IP. Problem is that the shutoff solenoid is firmly in the way. If I can remove it temporarily while I screw in the T, I'd be golden.
Unfortunately I'm not familiar enough with diesel injection pumps to know whether this is ok to do or not. Can I remove the solenoid temporarily - then once the T and sender and fuel line is re-attached - put it back in? Is there any set of procedures that I need to follow in order to do this?
Thanks in advance!
Thanks in advance!
