I can't express how bad these 1992 GM 4 wheel ABS systems were. Worked isn't the correct word to use. You are better off without this low bidder ABS system that simply releases the brakes so you can't stop.
GM's low bidder idea for 1992 4 Wheel ABS was to Simply. Release. Brakes. You then don't stop. I bent the brake pedal on one of those 1992 POS systems in a clone Olds Bravada (A total POS in it's own right and a dammed good example why Olds is no longer a GM brand anymore) trying to get the dammed thing to stop. Generally they "go off" when you hit the paint stripe for say a crosswalk and simply don't recover and keep going off. I had hit an ice patch, but, was off of it and the ABS was still going off when it plowed into the car ahead of me that, now like me, wasn't on ice. I would have stopped just fine if the ABS hadn't released the brakes over the initial skidding.
I would go newer or leave the 1992 ABS "off". It's simply dangerous and that's not figuring the major changes of a different vehicle sitting on top of it.
